access PtrList from chemistryModel
Like Tree1Likes
  • 1 Post By einstein_zee
Old   January 13, 2020, 12:34
Default access PtrList from chemistryModel
ssa
ssa_cfd is on a distinguished road
Hi all,
I created a PtrList to create multiple volScalarField in createFields.H
The code looks like this: (in createFields.H)
label N = 325;
    PtrList<volScalarField> kf(N);
for(int i = 0; i < N; i++)
word kfi ("kf" + name(i));
    kf.set
        i,
        new volScalarField
            IOobject
                kfi,
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
                IOobject::AUTO_WRITE
            mesh,
    dimensionedScalar(kfi, dimless, 0.0)
Now I want to access this volScalarField from chemistryModel.c.
currently my code looks like below in chemistryModel.c
volScalarField tkf = mesh1.lookupObject<volScalarField>(kfi);
tkf[celli] = R.kf(pkf, Tkf, c2);
Now it stores the caluclated values only in "tkf[celli]" but doesn't change the value of "kfi" globally.
What should I do to modify the "kfi" values globally.
ssa_cfd is offline   Reply With Quote
Old   January 14, 2020, 06:12
Yogesh Bapat
ybapat is on a distinguished road
You have created local variable volScalarField. You need to use reference to original volScalarField then only it will be updated globally.
Regards,
-Yogesh
ybapat is offline   Reply With Quote
Old   January 14, 2020, 07:36
ssa
I tried like this
const volScalarField& tkf = mesh1.lookupObject<volScalarField>(kfi);
and I got the below error
lnInclude/chemistryModel.C: In instantiation of ‘Foam::scalar Foam::chemistryModel<CompType, ThermoType>::solve(const DeltaTType&) [with DeltaTType = Foam::Field<double>; CompType = Foam::psiChemistryModel; ThermoType = Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> >; Foam::scalar = double]’:
lnInclude/chemistryModel.C:1079:43:   required from ‘Foam::scalar Foam::chemistryModel<CompType, ThermoType>::solve(const scalarField&) [with CompType = Foam::psiChemistryModel; ThermoType = Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> >; Foam::scalar = double; Foam::scalarField = Foam::Field<double>]’
chemistrySolver/chemistrySolver/makeChemistrySolvers.C:91:1:   required from here
lnInclude/chemistryModel.C:929:13: error: assignment of read-only location ‘(& tkf)->Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::<anonymous>.Foam::DimensionedField<double, Foam::volMesh>::<anonymous>.Foam::Field<double>::<anonymous>.Foam::List<double>::<anonymous>.Foam::UList<T>::operator[]<double>(celli)’
Then I tried like this
and then I got the below error
lnInclude/chemistryModel.C:917:62: error: invalid initialization of reference of type ‘Foam::volScalarField& {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&}’ from expression of type ‘const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>’
Old   January 14, 2020, 08:11
Hosein
einstein_zee is on a distinguished road
lookupObjectRef
einstein_zee is offline   Reply With Quote
Old   January 14, 2020, 08:26
ssa
I think lookupObjectRef is available only in latest versions. I use version 2.4 because the solver was previously written in this version 2.4
Old   January 14, 2020, 09:47
Hosein
oh, that is too old. There might be a better solution but I think you can use const_cast. sth like this const_cast<volScalarField&>(tkf)[celli] ....
ssa_cfd likes this.
Old   January 15, 2020, 07:17
ssa
Thanks Hosein. const_cast solved the problem.!!
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 15:13
Why is access to turbulence fields provided as const? mrishi OpenFOAM Programming & Development 3 January 23, 2020 12:51
Is there a way to access the gradient limiter in Fluent ? CFDYourself FLUENT 1 February 16, 2016 05:49
Temperature linearly rising after restarting a simulation Gennaro OpenFOAM Programming & Development 2 September 2, 2014 07:58
Newbie Question on PtrList usage chyczewski OpenFOAM Programming & Development 6 October 1, 2013 16:39
