solve Laplace eqn around an arc shaped geometry |
January 17, 2020, 16:25 |
Rep Power: 7 |
Hello everybody
I want to solve the Laplace equation in a vacuum solve ( fvm::laplacian(V) ); subject to a 2D electrode charged to a constant voltage 1000V and with a spherical arc shape (but not a sphere as I don't want it to enclose a 3D domain) . So let it lie inside a very large bounded box where we approximate the electric field to be 0 on all sides of this box. Therefore, file casename/0/V contains the following snippet: boundaryField { farfield { type fixedGradient; gradient uniform 0; } } The question is how to code the 1000V voltage condition on this arc since it is not on a patch (it is not on the boundary of a 3D domain) For those who prefer a fluid dynamics setting, you could have the analogous problem (in 2D though not 3D !!) with an incompressible irrotational fluid. Voltage V would be replaced by a streamline phi, phi would be constant on the circular arc and gradient uniform 0 becomes gradient uniform Velocity; Have a nice weekend |
January 20, 2020, 11:06 |
Rep Power: 7 |
I believe the answer is that the OPEN arc is a limiting case of a very thin CLOSED surface and is treated in many analytic fluid dynamics books. Afterall, in real life, we deal with a 3D body surrounded by air. In openFoam, this closed surface does indeed become a boundary of the outer air domain.
So unless somebody has anything to add, this thread is closed. Thanks for watching |
[Other] Change the mesh in mixerVesselAMI2D tutorial | hoemmaria | OpenFOAM Meshing & Mesh Conversion | 2 | October 6, 2017 07:43 |
k-omega SST flow over a cylinder | GP_FDU | OpenFOAM Running, Solving & CFD | 29 | January 15, 2016 15:06 |
[blockMesh] multiregion mesh with blockMesh | alvora | OpenFOAM Meshing & Mesh Conversion | 44 | July 21, 2013 14:14 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
How to solve another continuum and momentum eqn? | west_wing | FLUENT | 0 | August 25, 2003 10:00 |
