January 20, 2020, 11:17 |
tmp also defined as variable
Rep Power: 7 |
I just find it curious that the compiler does not complain about my use of a variable
volScalarField tmp since there is already a template class tmp<Type> defined in openFoam Regards to all |
January 21, 2020, 15:51 |
Rep Power: 7 |
This question was maybe a tad too difficult but don't worry: I will simply change tmp to another name that will not conflict with any type or name openFoam is using. It's no big deal. I was just curious.
[Workbench] Ansys error: The environment variable SAM_EXE is not defined | tarabaharan | ANSYS Meshing & Geometry | 0 | August 4, 2016 02:17 |
OpenFoam-1.6-ext Allwmake compilation error - one last barrier | Pat84 | OpenFOAM Installation | 15 | July 25, 2012 21:49 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
Problems with additional variable | Krishna Premi | CFX | 1 | October 29, 2007 08:19 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
