tzaht |
February 5, 2020 20:44 |
Vorticity in OpenFOAM; Negative to when I compute from fvc::grad(U)
Hi there,
I output the values of the velocity gradient tensor, as well as, the vorticity for my simulation.
Let's just consider the rotation about the x-axis for simplicity.
The problem that I am having is that when I compute , this is the definition of curl in the OpenFOAM Programmer's guide 2.1.3. Howeber, I actually get the negative of the vorticity in the standard OpenFOAM output file.
Now, when I again follow the maths in the Progammer's guide, I see that OpenFOAM is actually computing the hodge dual of the rotation rate tensor, so for [math] \omega_x = \omega_{23}[\math]. This should indeed be .
Now, the only thing I can think of that I may be doing wrong is that I assume that OF is writing the VGT in the following order:
Any help appreciated.
