fluid orce to solid patch icofsifoam
Like Tree1Likes
  • 1 Post By bigphil
Old   February 9, 2020, 13:25
Default fluid orce to solid patch icofsifoam
xena
xena is on a distinguished road
My question is about the fluid force applied on the solid patch in icodymfoam, what we find in setMotion.H, is juste pressure, !! Is the correct force implemented elsewhere ?
regards
xena is offline   Reply With Quote
Old   February 9, 2020, 15:03
HPE
Herpes Free Engineer
HPE is on a distinguished road
The Q is a bit broad, isn't it?
Kind regards,
HPE
The OpenFOAM community is the biggest contributor to OpenFOAM; not person A or B. Let's report bugs or issue feature requests in GitLab-OpenFOAM.
Please `design` your questions well. Such effort always pays off well for inquirers and `helpmate`s:
How to create a Minimal, Reproducible Example,
How to give enough info to get help.
HPE is offline   Reply With Quote
Old   February 10, 2020, 03:47
xena
ok sorry, i will explain it better.
at the fluid-structure interface, we have as BC the equality of constraints (file attached). But when I checked in setpressure.H of icodymfoam it looks like this :
scalarField solidPatchPressure =
interpolatorFluidSolid.faceInterpolate
p.boundaryField()[fluidPatchID]
solidPatchPressure *= rho;
tForce.pressure() = solidPatchPressure;
vector totalPressureForce =
sum
p.boundaryField()[fluidPatchID]*
mesh.Sf().boundaryField()[fluidPatchID]
So there isn't the part of the force due to the velocity and the viscosity.
Am I rignt, or is it done elswhere in the code.
Regards
Old   February 18, 2020, 17:37
HPE
Oh yeah, I think so.
I think what you are looking for is an active research topic, thats why it is not available thereat or somewhere else I think.
Kind regards,
HPE
Old   February 24, 2020, 09:54
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
As noted previously, the icoFsiFoam solver only passes pressure to the solid and ignores viscous stresses e.g. see other threads:
Fluid Structure Interaction using icoFsiFoam Problems
You can try later FSI solvers that include both e.g. extend-bazaar and solids4foam.
Philip
xena likes this.
bigphil is offline   Reply With Quote
Old   February 24, 2020, 10:52
xena
Originally Posted by bigphil View Post
Philip
Thanks,
Is it possible to add it to the current code?
I made some changes, so I want to continue using icofsifoam for the time being!
Regards
Old   February 24, 2020, 15:10
bigphil's Avatar
Philip Cardiff
Hi xena,
You can find steps on the thread in my previous post.
Philip
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 113 June 25, 2019 01:58
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
