March 19, 2024, 05:52 |
Vorticity calculation
Divyaprakash
Rep Power: 11 |
I need to calculate vorticity at every time-step since I need to use it for some other calculations. I will be doing that using
W = fvc::curl(U) My query is about the locations of the generated field, W. Is it stored at the cell centers or at the cell face centers? |
March 19, 2024, 10:37 |
Shravan
Rep Power: 9 |
To answer it in short, cell centres. Two ways to find out Method 1 Take a look at the vorticity functionObject. https://www.openfoam.com/documentati...8H_source.html https://www.openfoam.com/documentati...8C_source.html See line 54 in vorticity.C. It kind of does what you want to do. Basically the same operation. Now let us look at vorticity.H, see lines 49 and 51. You see that input (which is a velocity) is of the type volVectorField and the output (which is vorticity) is also of the type volVectorField. The data of the type volVectorField is stored in cell centres. Method 2 Just print out your vorticity. Code:
w.write() Thanks |
fvc, location, vorticity |
Transfer output data as input for second calculation | mannobot | Main CFD Forum | 3 | December 7, 2018 09:37 |
Incompressible Navier-Stokes in Stream Function - Vorticity Formulation | Daco | Main CFD Forum | 3 | May 29, 2016 01:28 |
Defining output as input for second calculation | mannobot | FLUENT | 1 | June 2, 2010 04:20 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
Vorticity Iso-Surface | John | Main CFD Forum | 0 | April 4, 2009 23:10 |
