Characteristic penalization implemented in fvOptions
Old   March 22, 2020, 11:17
Default Characteristic penalization implemented in fvOptions
Giorgio Negrini
alfiogn is on a distinguished road
I'm trying to implement an fvOption to add a new source to my solver without implementing a new solver.
In particular, what I want to do is applying a Brinkman penalization term to impose velocity or temperature in a certain cellSet like a Dirichlet condition. (I want to do it also for a Neumann condition but it is a further step).
It's something like an immersed boundary. I've to implement it for my phd studies.
Analytically the term is represented by:
\frac{1}{\epsilon} ( u - \bar{u})
where u is my unkown variable, \bar{u} is the viariable field that I want to impose and \epsilon is the penalization coefficient (10^-6 ~ 10^-12). I also want to treat u implicitly.
I've implemented an fvOption template for scalar and vector variables. The key part is the following:
template<class Type>
void Foam::fv::PenalizationSource<Type>::addSup
    fvMatrix<Type>& eqn,
    const label fieldi
    const volFieldType& psi = eqn.psi();
    eqn += (fvm::Sp(Chi_/epsilon_, psi)
            - fvc::Sp(Chi_/epsilon_, Ubar_));
Chi_ is a characteristic function, Ubar_ is the imposed value.
volFieldType is a typedef for a GeometricField<Type>.
What happens during simulations is that the velocity field explodes but I cannot imagine how to fix this problem. Maybe my code is wrong.
I think that the problem is in the summation of the fvm and fvc terms to my equation but I didn't figured out why.
Can someone help me?
Thanks in advance
Giorgio
UPDATE:
Maybe I found out the issue: the fvc term is added well, but the fvm one is not added to the equation. In this way I have an unbalanced source term (10^10 in rhs and the normal matrix in lhs).
However I don't know how to fix it.
alfiogn is offline   Reply With Quote
Old   March 23, 2020, 05:44
Giorgio Negrini
I feel stupid but I don't understand the reason why now the code is working perfectly. I just changed the sign of the fvm and fvc term.
Can someone explain me what is the difference between now and before?
    const label fieldi
    eqn -= (fvm::Sp(Chi_/epsilon_, psi)
And it is NOT working if I write
    const label fieldi
    eqn -= (-fvm::Sp(Chi_/epsilon_, psi)
                + fvc::Sp(Chi_/epsilon_, Ubar_));
fvOptions limitTemperature crashing in compressibleInterFoam JM27 OpenFOAM Running, Solving & CFD 38 November 29, 2023 03:55
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 07:55
Configuration of boundary conditions and fvOptions file Raza Javed OpenFOAM Running, Solving & CFD 16 May 3, 2019 16:35
New output variable for source term in fvoptions - without changing the solver vincent.clary OpenFOAM Programming & Development 2 June 26, 2018 05:21
Origin of rotorDiskSource implemented in fvOptions raye_xie OpenFOAM Programming & Development 2 April 20, 2018 02:27
