Compiling a new thermophysical model
Like Tree1Likes
  • 1 Post By Gerry Kan
Old   March 24, 2020, 06:28
Default Compiling a new thermophysical model
stockzahn's Avatar
stockzahn is on a distinguished road
Dear Foamers,
I'm making my own thermophysical model. For that reason I wrote some functions I want to you use to calculate the different properties (in thermoI.H, and the respective rho*I.H, transport*I.H, thermo*I.H files). I include the header-file declaring all my functions in "thermoI.H", otherwise the compilation fails, since my functions are not defined.
The compilation of libspecie works w/o problems, but when I try to compile libfluidThermophysicalModels (in the "basic" folder), I get compiler errors telling me, that my functions are multiple defined, e.g. a small fraction of the error message:
Make/linux64GccDPInt32Opt/rhoThermo/rhoThermos.o: In function `PN_sSCByPT(double, double)':
rhoThermos.C:(.text+0x6bce0): multiple definition of `PN_sSCByPT(double, double)'
Make/linux64GccDPInt32Opt/psiThermo/psiThermos.o:psiThermos.C:(.text+0x6bce0): first defined here
These lines occur for all of my functions twice:
- for psiThermos.o & rhoThermos.o
- for psiThermos.o & liquidThermo.o
It seems like the compiler declares the functions several times, since their definitions are called by "thermoI.H". I now tried several options to circumvent that issue, but without success. Does anybody has an idea how to solve that issue?
Sincerely,
stockzahn
stockzahn is offline   Reply With Quote
Old   March 24, 2020, 09:24
Gerry Kan's Avatar
Gerry Kan
Gerry Kan is on a distinguished road
Dear Stockzahn:
It sounds like you might need to implement include guards to your header file, so that all the objects / functions only get declared once during compile.
You should surround the contents of your header file with the following lines":
#ifndef __YOUR_HEADER_NAME__
#define __YOUR_HEADER_NAME__
  // contents of your original header file goes here
#endif
Hope that helps, Gerry.
stockzahn likes this.
Gerry Kan is offline   Reply With Quote
Old   March 24, 2020, 11:10
stockzahn's Avatar
Dear Gerry,
thanks for the fast response, unfortunately that didn't work.
stockzahn
EDIT: I solved it: obviously a very beginner's mistake: I tested the functions in a different program, for which in included all C-files in the header files. This was the problem, I just copied all files into the inlude-folder and deleted the #include-commands in the header-files. But thanks for the hint with the include guards! That will be advantegeous in the future.
[IHFOAM] The IHFOAM Thread Phicau OpenFOAM Community Contributions 311 March 25, 2020 10:15
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 18:19
viewFactor radiation model stuck shach934 OpenFOAM 0 September 16, 2019 18:14
Thermophysical transport model to include shear rate Janez Turk OpenFOAM Programming & Development 3 March 24, 2018 11:30
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
