how to monitor the plusant velocity using swak4Foam |
March 25, 2020, 01:34 |
王子阳
Rep Power: 6 |
hello everyone!
i want to output the pluse velocity during calculating time,so i insert the some functions to the ControlDict, they are as follows, fieldAverage1 { type fieldAverage; functionObjectLibs ( "libfieldFunctionObjects.so" ); outputControl outputTime; enabled true; fields ( U { mean on; prime2Mean on; base time; } ); } uix { type expressionField; autowrite true; expression "U.x-UMean.x"; outputControl outputTime; dimension [0 1 -1 0 0 0 0]; fieldName uix; } but when i run the programe, the error are as follows, --> FOAM FATAL ERROR: Parser Error for driver FieldValueExpressionDriver at "1.5-9" :"field UMean not existing or of wrong type" "U.x-UMean.x" ^^^^^ why UMean not existed? i also use the fieldaverageFunction to output it anyone can help me? best wishes! ziyang |
monitor plusant velocity |
LES and TKE calculations | MST | Main CFD Forum | 3 | May 30, 2016 06:26 |
Jumping droplets velocity - interFoam | Zinedine | OpenFOAM Running, Solving & CFD | 0 | October 6, 2015 08:25 |
[swak4Foam] problem with a parabolic velocity profile | Claudio87 | OpenFOAM Community Contributions | 5 | May 29, 2014 09:30 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
