how to monitor the plusant velocity using swak4Foam
hello everyone!
i want to output the pluse velocity during calculating time,so i insert the some functions to the ControlDict, they are as follows, fieldAverage1 { type fieldAverage; functionObjectLibs ( "libfieldFunctionObjects.so" ); outputControl outputTime; enabled true; fields ( U { mean on; prime2Mean on; base time; } ); } uix { type expressionField; autowrite true; expression "U.x-UMean.x"; outputControl outputTime; dimension [0 1 -1 0 0 0 0]; fieldName uix; } but when i run the programe, the error are as follows, --> FOAM FATAL ERROR: Parser Error for driver FieldValueExpressionDriver at "1.5-9" :"field UMean not existing or of wrong type" "U.x-UMean.x" ^^^^^ why UMean not existed? i also use the fieldaverageFunction to output it anyone can help me? best wishes! ziyang |
