production of kinetic energy Pk near wall cell? |
April 30, 2020, 04:00 |
The production of kinetic energy near wall cell is referred by which paper?
G0[celli] += w *(nutw[facei] + nuw[facei]) *magGradUw[facei] *Cmu25*sqrt(k[celli]) /(kappa_*y[facei]); I found Spalding's formula is not the same as above (Pk =Cmu^0.25*Utau^2*U/y). Anybody knows this issue? |
May 1, 2020, 06:19 |
Nobody is interested in this issue?
May 1, 2020, 13:20 |
CFD USER
Rep Power: 6 |
You can find the answer here: Wall functions - questions about implementation
May 3, 2020, 17:13 |
Herpes Free Engineer
Rep Power: 12 |
most of the time papers do not equate to the actual implementations. some code involve heuristic changes based on extensive number of tests in various scenarios.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 4, 2020, 04:50 |
#5 | |
May 4, 2020, 04:55 |
#6 | |
Yes. I am confused that the difference between those two methods for calculating Gk which I found in one paper. It seems that they are consistent with each other. But after I used those two formula, which leads to different results. |
May 6, 2020, 09:44 |
Nobody can explain this issue?
Turbulence kinetic energy at the wall | KR27 | Main CFD Forum | 5 | January 9, 2018 08:56 |
Production of Turbulent Kinetic Energy | johndeas | OpenFOAM | 1 | December 14, 2010 09:22 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 13:22 |
