You declared your k field as a const reference and then you tried to modify it which is not allowed.
Thanks for your reply. Yes, you are right. After I changed the codes as following:
tmp<volScalarField> tk = turbModel.k(); volScalarField k = tk(); It can be compiled successfully but the results are absolutely wrong. Could you please give me some suggestions? I also refered the epsilonwallfunction that updates the epsilon near wall cell. But there is always problem I met. Do you think it is possible to write something to update the k near wall cell by using the formulation? In kwallfunction or epsilonwallfunction? |
Can you show the line in your code where turbModel is defined
4 Attachment(s)
I attached my wall functions:(1)kwallfunc (2)epsilonwallfunc
I hope you can help me to check them. I hope I can use one of them to reach my goal. I wanna force k in the near wall center equals to Utau^2/sqrt(Cmu), which I defined in the .C file. |
You've got a copy of the field here
volScalarField k = tk(); Code:
volScalarField& k = tk(); |
After I changed like you suggested,
tmp<volScalarField> tk = turbModel.k(); volScalarField& k = tk(); There was compiling error: derivedFvPatchFields/wallFunctions/kqRWallFunctions/kOngWallFunction/kOngWallFunctionFvPatchScalarField.C: In member function 'virtual void Foam::kOngWallFunctionFvPatchScalarField::updateCo effs()': derivedFvPatchFields/wallFunctions/kqRWallFunctions/kOngWallFunction/kOngWallFunctionFvPatchScalarField.C:189:28: error: binding reference of type 'Foam::volScalarField& {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>& ' to 'const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>' discards qualifiers volScalarField& k = tk(); |
Hi, I changed the codes as following, but the result dosn't change, k in the first grid is still not calculated by my formulation. I cannot understand.
tmp<volScalarField> tk = turbModel.k(); volScalarField k = tk; const tmp<scalarField> tnuw = turbModel.nu(patchi); const scalarField& nuw = tnuw(); const tmp<scalarField> tnutw = turbModel.nut(patchi); const scalarField& nutw = tnutw(); const fvPatchVectorField& Uw = turbModel.U().boundaryField()[patchi]; const scalarField magGradUw(mag(Uw.snGrad())); const scalar Cmu25 = pow025(Cmu_); scalarField& kw = *this; forAll(nutw,facei) { label celli = patch().faceCells()[facei]; k[celli] = ((nutw[facei] + nuw[facei])*magGradUw[facei])*((nutw[facei] + nuw[facei])*magGradUw[facei])/(Cmu25*Cmu25); } |
volScalarField& k = tk.ref(); |
Thanks for your help. I found that even though I changed the value of k near wall cell, after calculated the kepsilon equations, the k here will be changed again. How to keep the k here always calculated by my formula?
Attempt to acquire non-const reference to const object from a tmp<N4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7 volMeshEEE> From function T& Foam::tmp<T>::ref() const [with T = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>] in file J:/blueCFD-Core-2017/OpenFOAM-5.x/src/OpenFOAM/memory/tmp/tmpI.H at line 187. FOAM aborting |
tmp<volScalarField> tk = turbModel.k(); |
epsEqn.ref().boundaryManipulate(epsilon_.boundaryF ieldRef()); I am thinking that I also need to apply this to k? Additionally, epsilon_.boundaryFieldRef().updateCoeffs() in kepsilon turbulence model is utillized to update the epsilon and G in the near wall cell while there is no k_.boundaryFieldRef().updateCoeffs() here. How k value in the boundary layer is refered if so? |
I can't help you much from now on. But your considerations on treating k in analogy with epsilon seem quite reasonable though.
Hi @yangqi!
Did you find a solution to your problem? Because I'm using a different k profile at the Inlet, I was attempting something similar to deal with BC at the wall. As a workaround, I use a new gradient formulation as a BC at the wall instead. Don't know if it good tough. By doing a gradient to the formulation you try to implement, it become 0. That why is ok to use zeroGradient at the wall if you use this type of k profile at the Inlet. Regards, |
