Problem: Updating temperature file
I am working with the InterCondensatingEvaporatingFoam. I am trying to do some changes because for my case it is not "physical enough". My problem is that the Output in the logSolver is not useful. I am just learning C++, so I am not a Professional for now. However, in the solver there is a reference for the temperature field in the beginning: volScalarField& T = thermo->T(); In the eEqn.H the energy-equation is set up and solved. Based on this field, the temperature is calculated by the following line and thus the protected variable T_ is updated: thermo->correct(); I've added another correct(alCheck,enCheck,Check,nmbrfaces) function, which calculates the temperature field in a different way (the original version leads to negative values for the temperature since the calculation for mixed cells (0<alpha<1) doesnt make sense). In my version T_ is also updated, I just changed the way how it is calculated. Now to the problem: If I check the logSolver, for example at Time=0.001 the temperature is not negative but already to low. For later times the log-file says that the min(T) is negative, which is in contrast to my T-Output (No vlaue lower than 76K, which is physical since I am simulating a cryogenic cooling case). In Paraview the temperature field of the "newVersion" has a minimum value of 76K, which is physical. At later times no negative values can be oberseved. So everything seems to be well. If I check the logSolver-file the Output says: min/max(T) = 21.6713, 673 GAMG: Solving for p_rgh, Initial residual = 0.01893, Final residual = 0.000186089, No Iterations 9 GAMG: Solving for p_rgh, Initial residual = 0.0123978, Final residual = 9.10196e-05, No Iterations 10 GAMG: Solving for p_rgh, Initial residual = 0.00364705, Final residual = 3.43957e-05, No Iterations 10 GAMG: Solving for p_rgh, Initial residual = 0.00118128, Final residual = 1.14063e-05, No Iterations 10 GAMGPCG: Solving for p_rgh, Initial residual = 0.000417309, Final residual = 8.1684e-10, No Iterations 16 ExecutionTime = 107.56 s ClockTime = 110 s Courant Number mean: 0.155013 max: 1.04568 deltaT = 1.38462e-06 Time = 0.001 After thermo->correct(alCheck,enCheck,Check,nmbrfaces) the following lines are written in the eEqn.H: En=thermo->he(); Info<< "min/max(T) = " << min(T).value() << ", " << max(T).value() <<endl; To say it in words: The En is updated based on e_, which is a protected Variable of the class. The Info Variabel is just the Output of the minimum and maximum value of the temperature. I do not understand why the minimum value should be negative at Time=0.001, because the temperature is not negative for all cells. So I do not understand what is the different between T in eEqn.H and the updated T_ in correct(), because T is just a Reference...Hopefully I have illustrated my problem well. Thanks in advance. |
