Methods of improving efficiency
Old   June 5, 2020, 06:35
Default Methods of improving efficiency
Sam
saj216 is on a distinguished road
Hello guys,
Are there methods for determining what affects the code of the solver which results in slow execution time. It is a transient solver, modified interThermalPhaseChangeFoam.
saj216 is offline   Reply With Quote
Old   June 6, 2020, 20:32
Sen Wang
wangsen992 is on a distinguished road
Use a profiler
wangsen992 is offline   Reply With Quote
Old   June 7, 2020, 05:18
Sam
Hello wangsen,
Thanks for the reply. Can you expand on how to achieve this. Information seems to be limited to this
https://openfoamwiki.net/index.php/HowTo_Profiling
Old   June 7, 2020, 21:17
Sen Wang
Hi Sam,
Profiling is kind of a general programming issue. Basically, you want to first have a C/C++ profiler that works on your operating system (depends on whether you use windows, mac or linux). Note here that if you run with single-thread, then a general profiler works. But if you want to profile the performance while running parallel cases, you should use a profiler supporting MPI, which from my experience only has proprietary ones.
Cheers,
Sen
Old   June 12, 2020, 16:11
Klaus
klausb will become famous soon enough
Maybe SCORE-P works for you:
Internet: https://www.vi-hps.org/projects/score-p
OpenFOAM setup: https://trac.version.fz-juelich.de/v.../config_ScoreP
Klaus
klausb is offline   Reply With Quote
Old   June 12, 2020, 16:13
Sam
Thanks Klaus,
I'll try it out.
Sam
CAMWA special issue on open-source numerical solver feixu2019 OpenFOAM Announcements from Other Sources 0 October 1, 2018 11:21
CAMWA special issue on open-source numerical solver feixu2019 SU2 News & Announcements 0 October 1, 2018 11:19
Efficiency of centrifugal compressor - Adiabatic walls vs CHT Burken CFX 0 May 11, 2018 12:53
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM kenn Main CFD Forum 2 July 18, 2004 18:28
Spectral methods efficiency Radu Bondar Main CFD Forum 1 December 4, 2001 13:25
