CodedSource controlled by a different region
Old   June 28, 2020, 20:53
Default CodedSource controlled by a different region
Alex
malydilnar is on a distinguished road
Hey all, ive been stuck at this problem for a while and am looking for your insight. I have a multi region conjugate heat transfer problem where I have a heater generating heat in its own region (Through scalar coded source / semi implicit source). I want to be able to turn the heater on/off based on the temperature read in a cell in a different region. (Thermostat controlling the heater)
The problem is it seems like I can only access the mesh inside the region the fvoptions file lives in for the coded source (The heater). Therefore I cant pull the temperature of a specific cell in a different region to use for my thermostat control.
This is my coded source so far, its really just copied parts from other forum users so far. The thermostat if conditions aren't there yet, because I need to figure out how to get the conditional thermostat into the coded source first.
test
    type          scalarCodedSource;
    active          true;
    name    sourceTime;
    scalarCodedSourceCoeffs
         selectionMode   all;
	       fields      (h);
        codeInclude
        codeCorrect
            Pout<< "**codeCorrect**" << endl;
        codeAddSup
	          scalar Tvol = 0;
            //const Time& time = mesh().time();
            const volScalarField& Tm = mesh_.lookupObject<volScalarField>("T"); // Look up temperature
            //Tvol = Tm.weightedAverage(mesh_.V()).value();                //averageValue of the volScalarField
            //const fvMesh& help = Tm.mesh().time();
            const vectorField& C = mesh_.C();                    //List of cellcentres
	          const scalarField& V = mesh_.V();
            //const scalarField& num = mesh_.C().size();
            scalarField& hSource = eqn.source();                //defining source
            forAll(C, i)
                //hSource[i] = (Tvol - 310)*2400*V[i] ;
                hSource[i] = (Tm[2] - 310)*2400*V[i] ;
            // Calling the mesh.C().size() method therefore yields the total size of the mesh.
            Pout << V << endl;
            Pout << "***codeAddSup***" << endl;
        codeSetValue
            Pout<< "**codeSetValue**" << endl;
        // Dummy entry. Make dependent on above to trigger recompilation
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
    sourceTimeCoeffs
         $scalarCodedSourceCoeffs;
As far as I can tell, mesh_.() only has access to the values of the mesh inside the region, not the combined mesh.
I have a couple of ideas on how to fix my problem, though I'm not very familiar with c++ so its difficult to really read all the source code and understand what methods I have at my disposal.
  • figure out how to extend mesh_.() to be able to pull temperature from a different region
  • it looks like coded source includes the sampling library, which should allow me to probe values, though again not sure if I can specify a different region to probe
Any input on how to solve my problem would be very appreciated, thanks.
malydilnar is offline   Reply With Quote
Error when solving p_rgh bob94 OpenFOAM 0 March 17, 2020 08:12
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 06:51
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
