How to write output only for cellset and not entire domain! |
August 26, 2020, 10:03 |
Tom Waits
Rep Power: 7 |
I have the following code in my fvOptions to write "USource" to a file. This works, however it writes "USource" for every cell in my domain, which is very slow. I am only interested in writing "USource" for the CellSet I define in topoSetDict. Could someone please help with a way to do this?
if (mesh_.time().outputTime()) { volVectorField momentumSourceField ( IOobject ( "momentumSourceField", mesh_.time().timeName(), mesh_, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh_, vector::zero ); forAll(cells, i) { momentumSourceField[cells[i]] = Usource[cells[i]]; momentumSourceField.write(); } Tom Waits |
August 26, 2020, 10:10 |
Yan Zhang
Rep Power: 11 |
Are you looking for this?
https://github.com/StachuraMichal/Op...sampleCellZone
https://openfoam.top |
August 26, 2020, 10:28 |
#3 | |
Tom Waits
Rep Power: 7 |
I was hoping for a minor modification to the code I posted to loop over the cells defined in toposet as opposed to the entire grid. As an aside, when I try to compile the code you sent, I get the following error: Code:
cellZoneSet/cellZoneSet.C:139:20: error: ‘const class Foam::dictionary’ has no member named ‘get’; did you mean ‘set’? zoneName_(dict.get<word>("cellZone")) ^~~ set cellZoneSet/cellZoneSet.C:139:28: error: expected primary-expression before ‘>’ token zoneName_(dict.get<word>("cellZone")) Regards, Tom Waits |
