max command hangs when using scotch decomposition
Hi everyone,
In my solver, there is a command as follows Code:
There is no problem, when I run in serial or parallel with simple decomposition. But when I use scotch decomposition, the solver hangs exactly at this point. I tried to comment out this line and then it runs smoothly. Does anyone know why? Thanks, ssa. |
If you want to find the max for a parallel case, try using gMax instead of max. There are loads of examples in the code, e.g. https://github.com/OpenFOAM/OpenFOAM...m/setRDeltaT.H.
Caelan |
