max command hangs when using scotch decomposition |
July 2, 2020, 03:55 |
ssa
Rep Power: 7 |
Hi everyone,
In my solver, there is a command as follows Code:
Info << "max/min Massendefekt: " << max(massendefektFeld).value() << " " << min(massendefektFeld).value() << endl; There is no problem, when I run in serial or parallel with simple decomposition. But when I use scotch decomposition, the solver hangs exactly at this point. I tried to comment out this line and then it runs smoothly. Does anyone know why? Thanks, ssa. Last edited by ssa_cfd; July 2, 2020 at 10:35. |
July 2, 2020, 10:59 |
Rep Power: 14 |
If you want to find the max for a parallel case, try using gMax instead of max. There are loads of examples in the code, e.g. https://github.com/OpenFOAM/OpenFOAM...m/setRDeltaT.H.
Caelan |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Converging Diverging Nozzle with dbnsTurbFoam | Saleh Abuhanieh | OpenFOAM Running, Solving & CFD | 4 | December 13, 2019 10:26 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
