add solid region to interfoam which has energy eqn
Old   July 22, 2020, 01:18
Smile add solid region to interfoam which has energy eqn
Ilhwan Yeo
jayson is on a distinguished road
Hello Foamers!
I am fairly newbie.. I want to simulate the combination of two phase flow and conjugate heat transfer. So, I now add solid region to interfoam which has energy equation.
I create the mesh for solid region and the fields for solid.
but I get error.. I think It is fairly correct code..
Foam::Info
<< "Create solid mesh for time ="
<< runTime.timeName() <<Foam::nl <<Foam::endl;
Foam::fvMesh solidMesh
Foam::IOobject
"wallRegion",
runTime.timeName(),
runTime,
Foam::IOobject::MUST_READ
Info<< "Reading solid thermophysical properties\n" <<endl;
autoPtr<solidThermo> wWallThermo(solidThermo::New(solidMesh));
solidThermo& wallThermo = wWallThermo();
Info<< "Adding to solidRho\n" <<endl;
volScalarField wallRho
IOobject
"solidRho",
runTime.timeName(),
solidMesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
wallThermo.rho()
Info<< "Adding to solild kappa\n" <<endl;
volScalarField wallK
IOobject
"solidK",
runTime.timeName(),
solidMesh,
wallThermo.Kappa()
Info<< "Adding to solidcp\n" <<endl;
volScalarField wallcp
IOobject
"solidcp",
runTime.timeName(),
solidMesh,
wallThermo.Cp()
Info<< "solve solid TEqn" << endl;
wallRho = wallThermo.rho();
wallK = wallThermo.kappa();
wallcp = wallThermo.Cp();
fvScalarMatrix TEqn
fvm::ddt(wallRho*wallcp, T)
-fvm::laplacian(wallK, T)
TEqn.relax();
TEqn.solve();
wallThermo.correct();
Info<< "Min/max solid T:" << min(wallThermo.T()).value() << ' '
<< max(wallThermo.T()).value() << endl;
/solid/createSolidFields.H: In function ‘int main(int, char**)’:
./solid/createSolidFields.H:31:1: error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject, Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> >)’
jayson is offline   Reply With Quote
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
Negative initial temperature error (chtMultiRegionFoam) jebin OpenFOAM Pre-Processing 59 March 26, 2020 13:36
alphat Wien3 OpenFOAM Running, Solving & CFD 22 August 15, 2019 11:00
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 16:53
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
