heo |
September 4, 2020 02:52 |
ggi mesh deformation problem
1 Attachment(s)
hi everyone!
I am implementing a piston motion using a foam-extend version.
I tried to use the existing openfoam 4.1 version of ACMI, but as the piston moves, the grid deforms, so I use the foam-extend version of the ggi.
However, despite using ggi, if you look at the attached picture, you can see that the grid at the top of the domain is deformed as the piston moves.
For dynamicmesh, dynamicInkJetFvMesh was used, and the boundary area between the piston and the domain was set to ggi.
How do I avoid grid deformation at the top of the domain?
polyMesh/boundary
Wedge1
type empty;
nFaces 1100;
startFace 13148;
Piston
type wall;
inGroups 1(wall);
nFaces 50;
startFace 14248;
Wedge3
type empty;
nFaces 1100;
startFace 14298;
SlipWall
type wall;
inGroups 1(wall);
nFaces 44;
startFace 15398;
Piston_out
type ggi;
nFaces 50;
startFace 15442;
shadowPatch Domain_in;
zone pzone;
bridgeOverlap true;
Wedge1
type empty;
nFaces 5600;
startFace 15492;
Wedge2
type empty;
nFaces 5600;
startFace 21092;
Wall
type wall;
inGroups 1(wall);
nFaces 40;
startFace 26692;
FarField
type patch;
nFaces 50;
startFace 26732;
Ypiston
type patch;
nFaces 40;
startFace 26782;
SlipWall2_Inlet
type wall;
inGroups 1(wall);
nFaces 90;
startFace 26822;
SlipWall2_Outlet
type patch;
nFaces 90;
startFace 26912;
Domain_in
type ggi;
nFaces 50;
startFace 27002;
shadowPatch Piston_out;
zone dzone;
bridgeOverlap true;
