October 17, 2020, 03:52 |
precomputing AMI weights
I was told and I also vaguely remember that there exist code that allows to precompute the AMI Weights in order to read them from a file during the simulation and save a lot of time when the mesh movement is periodic and over a lot of rotations or oscillations.
I've searched the web and the code and what I found that was closest to that only allowed to store maximum and minimum weights, with does not serve my purpose. Can someone point me to the related code (or publication if no code is available)? |
January 25, 2021, 06:51 |
dario
Rep Power: 9 |
Hi Louis, did you find any code on this topic?
January 25, 2021, 07:18 |
Unfortunately. I'll ask Eugene de Villiers if he can pitch in, while also knows about the implementation.
February 21, 2023, 07:28 |
Eugene de Villiers
Rep Power: 21 |
Hi Louis,
My memory is hazy. I think it was someone at Virginia Tech. You can try to reach out to Jonathan Pitt. It could be one of his students, but I am not sure. (contact details at the bottom of this page: https://www.cpe.vt.edu/ofw15/hosting.html) Good luck. Eugene |
December 7, 2023, 07:04 |
Rep Power: 7 |
Hi Louis,
did you ever find a solution to your problem? Thanks! |
December 7, 2023, 07:15 |
Hi, no, I,ve heard the new AMI is faster, but I'm working with other issues now.
[swak4Foam] reconstructPar error in MRFsimpleFoam (ami apprach) using GroovyBC velocity inlet | Krao | OpenFOAM Community Contributions | 3 | August 19, 2019 05:40 |
mapField error | rvl565 | OpenFOAM Pre-Processing | 1 | September 6, 2018 16:13 |
Help compiling code (newbie) | thsb20 | OpenFOAM Programming & Development | 56 | August 24, 2016 04:24 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
