April 5, 2021, 20:41 |
createFields dimensionedVector deprecated?
Anonymous.
Rep Power: 5 |
Hi all,
I am currently using OFv2006 and is trying to declare a new vector in createFields.H I used the following code: Info<< "Reading the laser beam heat source\n" <<endl; IOdictionary beamProperties ( IOobject ( "beamProperties", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); dimensionedVector Ulaser ( "Ulaser", dimensionSet(0,1,-1,0,0,0,0), beamProperties //.lookup("Ulaser") ); But the error of the following came out: "warning: ‘Foam::dimensioned<Type>::dimensioned(const Foam::word&, const Foam::dimensionSet&, Foam::Istream&) [with Type = Foam::Vector<double>]’ is deprecated: Since 2018-11 [-Wdeprecated-declarations] );" I think it is deprecated since 2018 version of OF. I am wondering where I can find the new way to declare a vector. Does anyone know the proper way to do it? |
February 21, 2022, 07:39 |
Same problem
Rosario Arnau
Rep Power: 9 |
Hi gentodin,
I'm facing the same problem. How did you fix this? Tanks a lot! |
meaning of two mesh key in createFields | AmirBaqa1987 | OpenFOAM Programming & Development | 1 | June 22, 2013 12:03 |
createfields C7H16 | viv05 | OpenFOAM | 5 | August 7, 2009 01:23 |
Propellerfanrotating machinery | clo | OpenFOAM Running, Solving & CFD | 7 | January 30, 2007 12:48 |
