Custom viscosity model wmake error
Hi everyone,
I am currently implementing a custom viscosity model, but when I try to compile it I receive the following error message Code:
Make/linux64GccDPInt32Opt/options:55: *** recipe commences before first target. Stop. while this is the customLaw/Make/files code Code:
customLaw.C Code:
EXE_INC = \ Thank you in advance. |
Solved.
I deleted the directory that was created in the Make directory from the previous failed compilation. Compiled again and it worked. No idea why it worked tho. |
Dear Raul, I am trying to simulate rising bubble in a solution that its density, viscosity nad surface tension are chaning with the concentration of solvent. I am using interFoam and I would like to implement my own correlations for calculating density, viscosity and surfance tension. I am new in OpenFoam and I am looking for a tutorial or any guidance to start it. Could you please help me or share any tutorial if you have for this problem? Thanks and best regards, Sadra |
