Darcy as coded source
Hey,
I would like to define my Darcy-parameter D local inside my porous media. Therefor I try to write a vectorCodedSource to change the "fvOptions(U)" sink term in my Ueqn.H from porousSimpleFoam solver. If if apply my code with constant D and nu hard coded, my velocity increases and I get wrong results. How can I applay change fvOptions(U) instead of U at the whole field (U changes not only in my filter cellZone). The next problem is that I dont know how to load nu out of transportProperties instead of hard coding it. Different lookup and other code snippets didnīt work. My fvOptions look like follows: Code:
/*--------------------------------*- C++ -*----------------------------------*\ Thanks in advance Chris |
Darcy-Forchheim should also be there in porous sources.
Can't you just use them, or in a modified form? Probably better than writing from scratch. |
Hey,
thanks for your answer. I know that Darcy-Forchheimer is already implemented. The problem is, that I am not deep enough inside all the code to understand the whole structure. I mean the place, where fvOptions calls DarcyForchheimer.C and how it is calculated there (I`m also not familiar with all OF defined functions, classes, templates for variables , ...). If I write my own code it`s easier to define my input for local permeability. To change the equations in DarcyForchheimer.C I need to know the whole part from fvOptions.C to DarcyForhcheimer.C so I can change the LIBS to my local coded data. That is another problem too. Thanks in advance. |
