Error about correctPhi during compilation
Like Tree8Likes
  • 7 Post By Genji
  • 1 Post By danielece04
Old   January 11, 2016, 01:11
Default Error about correctPhi during compilation
Federica
fkika is on a distinguished road
Hi everybody,
I'm trying to compile a new solver, but during the compilation I have this error:
correctPhi.H:2:1: error: expected constructor, destructor, or type conversion before ‘(’ token
In file included from correctPhi.H:11:0,
from myInterPhaseChangeFoam.C:41:
/opt/OpenFOAM/OpenFOAM-3.0.0/src/finiteVolume/lnInclude/continuityErrs.H:32:1: error: expected unqualified-id before ‘{’ token
What is wrong with my solver?
The correctPhi.H file is this:
CorrectPhi
U,
phi,
p_rgh,
dimensionedScalar("rAUf", dimTime/rho.dimensions(), 1),
geometricZeroField(),
pimple
#include "continuityErrs.H"
I am using OpenFoam 3.0.0
Thank you!
fkika is offline   Reply With Quote
Old   January 26, 2017, 14:16
Linyan X
linyanx is on a distinguished road
Hi my friend,
Were you create your solver based on 'interFoam' solver? Is there anything updated for this system's complaint? I am also facing this problem.
Regards,
Linyan
linyanx is offline   Reply With Quote
Old   June 16, 2017, 06:27
Nguyen Duy Trong
ndtrong is on a distinguished road
Originally Posted by fkika View Post
Hi everybody,
CorrectPhi
U,
phi,
p_rgh,
pimple
Thank you!
Dear Federica
Have you solved your problem, could you please share with me the way to overcome it?
Thanks in advance
ndtrong is offline   Reply With Quote
Old   November 1, 2017, 18:55
Genji is on a distinguished road
Hi
I faced the same error while trying to build a custom interFoam solver. What solved it was being more specific about the include CorrectPhi.H (Capital C) . So, at the includes before main I changed
#include "CorrectPhi.H" with
#include "cfdTools/general/CorrectPhi/CorrectPhi.H", and added
-I$(LIB_SRC)/finiteVolume \
to my options file.
We are not using the same version of OpenFOAM but I hope this helps.
Genji is offline   Reply With Quote
Old   November 27, 2017, 15:53
Nguyen Duy Trong
Originally Posted by Genji View Post
Hi
to my options file.
Hi Genji,
It works well.
Thank you very much for your suggestion.
Old   December 2, 2020, 07:03
Daniele
danielece04 is on a distinguished road
Hi
to my options file.
I faced the same error while trying to compile ihFoam on Mac (via Docker). Thanks to your suggestion, I solved modifying the main, in which I changed
#include "path/where/CorrectPhi/is/effectively/located", (in my case /opt/OpenFOAM/OpenFOAM-v2006/src/finiteVolume/lnInclude/CorrectPhi.H)
Thank you very much!
sherlock45 likes this.
danielece04 is offline   Reply With Quote
Old   June 5, 2021, 16:03
Deshik
sherlock45 is on a distinguished road
Hi! I have tried all the suggestions you gave in this thread. Earlier I used to get errors, and when I followed all your suggestions, now I didn't get any. But when I run a test case I didn't get the results. (you can see in the image)
If anyone resolved this issue completely please help..
I have also attached the appropriate files....
Thanks in advance..
File Type: h correctPhi.H (166 Bytes, 15 views)
sherlock45 is offline   Reply With Quote
Compilation error for OpenFOAM-ext on Ubantu 10.04 32 bit Sargam05 OpenFOAM Installation 13 March 22, 2014 05:21
[swak4Foam] swak4Foam compilation for OF-2.0.0 camoesas OpenFOAM Community Contributions 19 December 10, 2012 13:24
Compilation Error (V 1.7.1; Icc 12.1.0, OpenMPI 1.4.3) floydfan OpenFOAM Installation 7 December 20, 2011 05:56
errors during compilation and installation of OpenFOAM-1.7.x on Ubuntu 10.04 ftec OpenFOAM Installation 7 February 23, 2011 06:07
Compilation Error.... Arnab Siemens 4 September 12, 2004 15:54
