Why is dictionary read twice in the scalarTransport functionObject?
Like Tree1Likes
  • 1 Post By simrego
Old   June 21, 2021, 10:04
Default Why is dictionary read twice in the scalarTransport functionObject?
Rishikesh
mrishi is on a distinguished road
in the ESI OpenFOAM source code for the file scalarTransport.C, if we look at the constructor, I understand that the bold text initializes members of the object. However, after this, read(dict) is called by the constructor, where it seems to me that the same dictionary is read again. Do these two calls to dictionary achieve different things and can we remove some redundancy here?
The constructor:
 Foam::functionObjects::scalarTransport::scalarTransport
    const word& name,
    const Time& runTime,
    const dictionary& dict
    fvMeshFunctionObject(name, runTime, dict),
    fieldName_(dict.getOrDefault<word>("field", "s")),
    phiName_(dict.getOrDefault<word>("phi", "phi")),
    rhoName_(dict.getOrDefault<word>("rho", "rho")),
    nutName_(dict.getOrDefault<word>("nut", "none")),
    phaseName_(dict.getOrDefault<word>("phase", "none")),
    phasePhiCompressedName_
        dict.getOrDefault<word>("phasePhiCompressed", "alphaPhiUn")
    D_(0),
    constantD_(false),
    nCorr_(0),
    resetOnStartUp_(false),
    schemesField_("unknown-schemesField"),
    fvOptions_(mesh_),
    bounded01_(dict.getOrDefault("bounded01", true))
    read(dict);
    // Force creation of transported field so any BCs using it can
    // look it up
    volScalarField& s = transportedField();
    if (resetOnStartUp_)
        s == dimensionedScalar(dimless, Zero);
The read(dict) function:
bool Foam::functionObjects::scalarTransport::read(const dictionary& dict)
    fvMeshFunctionObject::read(dict);
    dict.readIfPresent("phi", phiName_);
    dict.readIfPresent("rho", rhoName_);
    dict.readIfPresent("nut", nutName_);
    dict.readIfPresent("phase", phaseName_);
    dict.readIfPresent("bounded01", bounded01_);
    schemesField_ = dict.getOrDefault("schemesField", fieldName_);
    constantD_ = dict.readIfPresent("D", D_);
    alphaD_ = dict.getOrDefault<scalar>("alphaD", 1);
    alphaDt_ = dict.getOrDefault<scalar>("alphaDt", 1);
    dict.readIfPresent("nCorr", nCorr_);
    dict.readIfPresent("resetOnStartUp", resetOnStartUp_);
    if (dict.found("fvOptions"))
        fvOptions_.reset(dict.subDict("fvOptions"));
    return true;
mrishi is offline   Reply With Quote
Old   June 22, 2021, 03:59
anonymous
simrego is on a distinguished road
Hi!
It is not exactly the same. In the constructor you set default values (getOrDefault). In the read() you read IF present (readIfPresent)
I guess it makes possible to reread the file during runtime, and yes there is a little redundancy but in the constructor you have to give values for these members that's why you use getOrDefault. But read() does some more so you have to call it.
So I think it is totally reasonable as long as you can modify it in runtime and you have to reread the file.
olesen likes this.
simrego is offline   Reply With Quote
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
Dictionary in turbulence model NewKid OpenFOAM Programming & Development 4 February 18, 2019 21:16
How read viscosity on Chinese rotational viscometer? abuhafss Main CFD Forum 0 January 22, 2019 02:44
driftFluxFoam viscosity model modification problem dleduc OpenFOAM Programming & Development 15 October 1, 2018 09:37
Read properties per component from an input file dictionary Cyp OpenFOAM Programming & Development 29 November 1, 2015 21:41
