Marangoni Convection - icoReactingMultiphaseInterFoam |
July 16, 2021, 11:04 |
Rep Power: 5 |
i am trying to implement the temperature dependent surface tension (Marangoni Convection). Too validate my Implementation I want to replicate the Case published by Tan. But my Results aren't satisfying and maybe someone can have a look into my case setup. The tangential surface tension component is implementent in UEqn: Code:
volScalarField alpha0 = fvc::average(fluid.phase(0)); volScalarField alpha1 = fvc::average(fluid.phase(1)); volVectorField gradAlpha = alpha1*fvc::grad(alpha0)-alpha0*fvc::grad(alpha1); volVectorField nn = gradAlpha/(mag(gradAlpha)+deltaN); volScalarField factor = (2*rho)/(fluid.phase(0).rho()+fluid.phase(1).rho()); fvVectorMatrix UEqn ( fvm::ddt(rho, U) + fvm::div(rhoPhi, U) //- fvm::Sp(fvc::ddt(rho) + fvc::div(rhoPhi), U) + turbulence->divDevRhoReff(U) - dSigmadT*(fvc::grad(T) - nn*(nn & fvc::grad(T)))*mag(gradAlpha)*factor == fvOptions(rho, U) ); I attached my case setup. I look forward to any advise. https://imgur.com/a/kD6QsQF L. Tan, S. Leong, E. Leonardi, and T. Barber, “A numerical study of solid-liquid phase change with marangoni effects using a multiphase approach,” Progress in Computational Fluid Dynamics, vol. 6, no. 6, pp. 304–313, 2006. |
July 17, 2021, 13:49 |
Rep Power: 5 |
Here is my case.
September 26, 2021, 03:21 |
XinZhou
Rep Power: 8 |
hello,Schmidtgen, have you solved this problem?Could you please share your method ?
October 20, 2022, 20:17 |
VINIT
Rep Power: 3 |
October 26, 2022, 04:43 |
Rep Power: 5 |
December 1, 2022, 12:42 |
Ching Liu
Rep Power: 8 |
I am also working on this solver, but different topic.
You introduced a void fraction in the U equation. Did you know how the void fraction is solved in this solver? I looked in the folder of this solver but did not find the void fraction transport equation. |
Marangoni Convection | CneSpaulding | STAR-CCM+ | 2 | June 6, 2014 07:38 |
Thermophysical properties for natural convection | Ciefdi | OpenFOAM Running, Solving & CFD | 0 | November 7, 2013 11:44 |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 04:12 |
Marangoni convection in CFX | shahpar73 | CFX | 3 | January 31, 2011 06:13 |
Marangoni Convection | Rucy | FLUENT | 0 | July 6, 2005 05:17 |
