V2106: Erroneous Velocity's on decomposePar
5 Attachment(s)
Howdy Yall:
I am having another problem as it pertains to case conversion from OFv2012 to OFv2106. Fortunately my last issue was solved, thanks Oleson :D, and I have since downloaded the openfoam_master source code. I can now convert my gmsh mesh into OpenFOAM and decompose it. Olesen's post in that thread has a link which will take to the resolved issue: https://www.cfd-online.com/Forums/op...esi-v2106.html Now I bring that thread up because I am getting erroneous values for the velocity on certain processors after I decompose the mesh. I originally thought this was a result of converting my mesh via v2012 and running in v2106. But now I am no longer certain. The first image is of the cellDist field as provided by: decomposePar -cellDist using a 32 core decomposition Attachment 85679 When visualizing the velocity field Proc16 stands out with a strange value. Shown in the next Image: Attachment 85680 Additionally, such an erroneous assignment exists on my inlet boundary. Mind the sliver as this is a "2d" case. Attachment 85681 Now the weird part. Normally, with such high velocities, you would expect the solver to crap out rather quickly. But it runs to completion. I manually checked the processor files for any values with "e+" mag>1000 as my inlet BC is 500 m/s and for the test case the velocity should cap around 950 m/s as the flow diverts around the cylinder. No values containing e+ are written to any of the processors at any timestep. Normally I would chalk this up as a Paraview error and be on my way.... Hell when I reload the files, the erroneous processors and values shift around. Additionally, when I view the cell data in Paraview for any timestep not = 0, see the next attachment. There are no erroneous velocity readings. Attachment 85682 vs interpolated by paraview Attachment 85683 So for time = 0 there is some sort of problem going on. Though I'm not certain what. The reason why I bring this up in the programming forum is because There are some interesting, previously non-observed, effects on the coupled lagrangian debris field. In what should be a a uniform velocity and temperature injection and a lognormal size distribution, there is a large amount of variance near the inlet on the reported Reynolds and Nusselt Numbers. I've hit the Image cap on this post and with post the views as well as a histogram of the various non-dimensional numbers on a comment post below. Placing the test case in the next message as well. Not including the source code of the particular solver as I am confident it is not the problem as this issue has, until now, not been encountered. v2012, v2006, v1912 works with the custom code I am working on. I do plan on releasing it once I've done some V&V though :D. |
3 Attachment(s)
Images of the particle Stokes, Nusselt and Reynolds Numbers.
Stokes Number Attachment 85686 Nusselt Number Attachment 85684 Reynolds Number Attachment 85685 The reported stokes number looks reasonable and it's distribution is very much lognormal. My issue with the Reynolds & Nusselt numbers isn't their distributions. Looking at the particles in the lower left hand corner of the domain you can see a distinct difference in particles entering near the bottom portion of the inlet. Nusselt numbers are lower than the rest of the particles entering the domain as are the reynolds numbers as well. |
Not able to attach the .zip file for some reason so I have attached a google drive link to the compressed test case.
https://drive.google.com/file/d/162M...ew?usp=sharing ---------------------------------------------- Currently working on*** Running the case as a serial process to see if it is truly an issue associated with v2106 parallelization. |
5 Attachment(s)
Ok so some new images.
When I look at the velocity of the serial test case and reload the files for visualization I can sometimes get a normal looking velocity field. The majority of the time I get the following: Correct-ish "not V&V'ed" Attachment 85690 Wrong Velocity Attachment 85691 For the same exact case ran in serial, I get the following distributions for Stokes, Nusselt and Reynolds. Stokes Number: Attachment 85687 Nusselt Number: Attachment 85688 Reynolds Number: Attachment 85689 Through visual inspection I can tell that there is something wrong as the solution has changed between the parallel and serial cases. Though the serial case looks more as I would expect for a uniform inlet and injection condition. |
