August 9, 2021, 06:11 |
Make my solver to work in parallel
Giovanni Luddeni
Rep Power: 5 |
Goodmorning,
I wrote a solver with some blocks of code where i manually alter some field values. Something like: Code:
forAll(field,c) { if (something) field[c]=1; } How can I have a code like this to work in parallel? In my case I have 2 regions, and I need to couple them using a 1-halo layer. So I need to update the values at the boundary manually and impose the boundary conditions using boundaryFieldRef. Having the simulation running on a single core only would be very limiting. Any help is appreciated. Thank you. |
August 14, 2021, 15:14 |
Klaus
Rep Power: 22 |
Please be more specific about your requirements/setup, I am not convinced, that you need MPI operations at all.
When you talk about two regions, do you mean two areas which are part of your problem description or do you want to decompose your domain into two parts to run your simulation on two cores? If you decompose you case to run it on multiple cores, are the settings (the values you want to introduce) for your "regions" influencing each other across processor boundaries which would require to transfer information from one core to another? |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
"Define_Profile" UDF for parallel solver | Antoine | Fluent UDF and Scheme Programming | 9 | February 29, 2016 06:09 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
RBF motion solver does not work well in parallel | lakeat | OpenFOAM Bugs | 3 | August 8, 2013 05:50 |
