An OpenFOAM solver for porous media nees help |
August 20, 2021, 01:03 |
An OpenFOAM solver for porous media needs help
Yang Zhe
Rep Power: 4 |
Hello, everyone, I developed a OpenFOAM solver for porous media, based on stressAnalysis-solidDisplacementFoam (OF version 4.x), It aims to solve two coupled equations about two variables(scalar p and vector U).
When I used this solver to solve a specific initial & boundary value problem, it is found that when the input parameter Sr=0.95 (so that coefficient Dp1=0.0266562,Dp2=2.61497E6), the calculation is successful and proceeds to the predefined end time, though the result is not correct(p field only varies within the very thin boundary). However, when I changed the parameter Sr from 0.95 to 1.0 with other parameters kept, the calculation broke down at the first time step and the initial residual of p could not be reduced form 1.0 as the iteration proceeded. I guess that the problem results from the solving of the equation system. Could anybody give me any suggestions? I want to attach the corresponding files for reference. But the "Attachments" button does not work. Could anybody tell me how to attach? Thank you all! Last edited by Yang Zhe; August 26, 2021 at 03:39. |
suGWFoam: Richards equation solver for porous media flows | liu | OpenFOAM Announcements from Other Sources | 4 | February 10, 2021 15:14 |
running OpenFOAM 2.2.0 case & solver on OpenFOAM V6 | Ash Kot | OpenFOAM Running, Solving & CFD | 0 | October 25, 2019 16:44 |
How to rewrite a standard OpenFOAM solver as a C++ class | cfbaptista | OpenFOAM Programming & Development | 7 | March 23, 2016 04:50 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
Can't get data from OpenFoam to external solver using externalCoupled | perry | OpenFOAM Running, Solving & CFD | 4 | May 26, 2014 08:09 |
