Compile OF codes with generic compilers?!
Old   September 30, 2021, 07:42
Default Compile OF codes with generic compilers?!
Ali Baratian
baratian is on a distinguished road
hello everybody
i wonder whether it is possible to run OF codes on a generic compiler (not through the TERMINAL determined by the official releases)?
for example can i run the Cavity tutorial codes on CodeBlocks C++ compiler?
i think if OF is a real open source code it must be possible!
thanks in advance.
baratian is offline   Reply With Quote
Old   September 30, 2021, 16:27
Klaus
klausb will become famous soon enough
Netbeans, Eclipse and QtCreator have been used by some people some time ago.
An example (QtCreator):
https://openfoamwiki.net/index.php/H...ng_application
klausb is offline   Reply With Quote
Old   October 9, 2021, 09:23
Ali Baratian
How about c++in codeblocks?
Old   October 10, 2021, 10:45
Klaus
I haven't used an IDE myself and whether you can use a specific IDE has nothing to do with OpenFOAM being an open source software. Also, codeblocks isn't a compiler it's an IDE that can be used with different compilers - you'll probably use the same compiler through the IDE/codeblocks which you would use on the command line/in the terminal.
Whether codeblocks can be used or not depends on whether it supports OpenFOAM "programing conventions" i.e. whether it can be configured (setup) to compile OpenFOAM applications or libraries which includes e.g. the use of wmake and wclean or defining the paths to relevant header files to enable autocomplete etc.
I'd suggest to use the configuration description of one of the IDEs used by others as a checklist and try the same setup in codeblocks step-by-step.
compiler terminal code
[waves2Foam] Compile waves2FoamMooring on OF1912 romainping OpenFOAM Community Contributions 5 October 11, 2021 17:52
[waves2Foam] Unable to compile the waveDyMFoam solver cesa OpenFOAM Community Contributions 1 May 25, 2021 12:34
Coupling FLUENT with monodimensional codes D.Martelli FLUENT 2 September 2, 2016 16:54
Compile error in compressible VOF codes alberto OpenFOAM Bugs 9 June 18, 2010 09:55
Anyone used Ansys/Flotran - cf. with other codes? S. Langsford Main CFD Forum 3 October 19, 1998 21:51
