Calculate surfaceScalarField in parallel (boundary processor)
Like Tree1Likes
  • 1 Post By fedez91
Old   October 2, 2021, 20:42
Default Calculate surfaceScalarField in parallel (boundary processor)
Federico Zabaleta
fedez91 is on a distinguished road
Hi everyone,
I have a diffusivity "D" calculated in the faces of the cell. I want to limit D on some faces (make it zero), when a parameter "P" (also defined in the faces) is smaller than "epsilon". The code I use works well, EXCEPT ON THE BOUNDARIES BETWEEN PROCESSORS. Attached is a figure of D calculated in series, and D calculated in parallel with 32 processors. You'll see that they are different ONLY in the boundaries between processors (indicated with the glyphs)
Following the implementation of flux limiters on MULES, I do the following (simplified code):
surfaceScalarField D(fvc::interpolate(D_cell));
scalarField allLambda(mesh.nFaces(), 1.0);
slicedSurfaceScalarField lambda
    IOobject
        "lambda",
        mesh.time().timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::NO_WRITE,
        false
    mesh,
    dimless,
    allLambda,
    false   // Use slices for the couples
scalarField& lambdaIf = lambda;
surfaceScalarField::Boundary& lambdaBf = lambda.boundaryFieldRef();
forAll(lambdaIf, facei)
    if(P[facei] < epsilon) {lambdaIf[facei] = 0;}
forAll(lambdaBf, patchi)
    scalarField& lambdaPf = lambdaBf[patchi];
    forAll(lambdaPf, pFacei)
        if(P[pFacei] < epsilon) {lambdaIf[pFacei] = 0;}
syncTools::syncFaceList(mesh,allLambda,minEqOp<scalar>());
D*=lambda;
I really don't understand where is my error or what I'm missing! I've been struggling a lot with this. Pleas HELP!
File Type: jpg Screenshot from 2021-10-02 17-37-49.jpg (30.6 KB, 15 views)
fedez91 is offline   Reply With Quote
Old   October 2, 2021, 22:39
Federico Zabaleta
Found the error. It was a stupid typo. It should have said lambdaPf and not lambdaIf on the boundary fields.
        if(P[pFacei] < epsilon) {lambdaPf[pFacei] = 0;}
CorbinMG likes this.
Boundary condition problem (Freestream) KAYANO OpenFOAM Running, Solving & CFD 5 June 1, 2021 05:57
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
