How to divide a vectorfield by the magnitude if the vector can be zero
Old   October 5, 2021, 18:24
Default How to divide a vectorfield by the magnitude if the vector can be zero
Torsten Schenkel
tschenkel is on a distinguished road
I am trying to do some postprocessing with normalised vectors. The vector can be zero, so the simple form:
Un = U/mag(U)
will break with segfault.
Un = U/(mag(U)+1e64)
doesn't work, because the dimensions won't match (1e-64) has dimension [0 0 0 ... 0]
Is there a trick to achieve that?
U is not the velocity, so a specific normalised velocity function wouldn't help. Would need to take any dimensionedVolVectorField.
tschenkel is offline   Reply With Quote
Old   October 6, 2021, 08:24
Michael Alletto
mAlletto will become famous soon enough
You should decide by a small dimensionized scalar. You can find an example here how to convert to dimensionless scalar in openfoam
mAlletto is offline   Reply With Quote
Old   October 6, 2021, 09:50
Torsten Schenkel
Thanks, that's very helpful. I was starting to play around with .value() and .dimensions().
Good to know that that is the right path.
Old   October 9, 2021, 06:09
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Need to check if the normalised(..) function works on GeometricFields or only on primitive fields, but could start looking there. It haves a check for ROOTVSMALL to protect the division.
olesen is offline   Reply With Quote
Old   October 9, 2021, 10:16
Torsten Schenkel
normalised() isn't defined for volVectorFields, it seems.
Old   October 9, 2021, 10:19
Default SOLVED: create a dimensionedScalar for the very small value epsilon
Torsten Schenkel
dimensionedScalar epsWSS = dimensionedScalar("epsWSS",WSS.dimensions(), 1e-64);
creates a very small scalar with dimension of the vector field, which can then be used as:
normalisedWSS = WSS / (mag(WSS)+epsWSS);
Velocity Magnitude not showing results musa19 Tecplot 1 November 18, 2020 23:49
HronTurekFsi3 foam-extend3.1 Maimouna OpenFOAM Running, Solving & CFD 112 April 20, 2019 21:11
Magnitude of a tensor mmkr825 OpenFOAM Programming & Development 8 December 12, 2018 13:49
'cell relative: velocity magnitude' vs 'velocity magnitude' alpharays Main CFD Forum 2 June 18, 2015 07:24
Stresseq vs stress magnitude watashiwa OpenFOAM 1 October 14, 2010 12:02
