October 7, 2021, 07:33 |
compiling a new solver using older one
kuldeep
Rep Power: 4 |
i am new to this openfoam, i am trying to add extra term(T j in momentum equation and n^2 * V in energy equation) and trying to compile it but getting this error:
candidate expects 2 arguments, 1 provided 71 | +fvc::Sp(T)); form of equation which i want in to add in my solver https://drive.google.com/file/d/1rzd...ew?usp=sharing new_Icofoam3.C /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Copyright (C) 2011-2018 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. Application new_icoFoam Description Transient solver for incompressible, laminar flow of Newtonian fluids. Added the temperature solver \*---------------------------------------------------------------------------*/ #include "fvCFD.H" #include "pisoControl.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCaseLists.H" #include "createTime.H" #include "createMesh.H" pisoControl piso(mesh); #include "createFields.H" #include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; #include "CourantNo.H" // Momentum predictor fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) ); if (piso.momentumPredictor()) { solve(UEqn == -fvc::grad((1/rho)*p) +fvc::Sp(T)); } // snGrad calculates the surface normal gradient for you. Since the surface normal // is only one direction, you will get one component for every component of velocity. // However if you input a scalar field, you will get only a scalar. // --- PISO loop i.e correcting the velocity while (piso.correct()) { volScalarField rAU(1.0/UEqn.A()); volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p)); surfaceScalarField phiHbyA ( "phiHbyA", fvc::flux(HbyA) + fvc::interpolate(rAU)*fvc::ddtCorr(U, phi) ); adjustPhi(phiHbyA, U, p); // Update the pressure BCs to ensure flux consistency constrainPressure(p, U, phiHbyA, rAU); // Non-orthogonal pressure corrector loop while (piso.correctNonOrthogonal()) { // Pressure corrector fvScalarMatrix pEqn ( fvm::laplacian(rAU, p) == fvc::div(phiHbyA) ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(); if (piso.finalNonOrthogonalIter()) { phi = phiHbyA - pEqn.flux(); } } #include "continuityErrs.H" U = HbyA - rAU*fvc::grad(p); U.correctBoundaryConditions(); /* here velocity is already calculated */ // now start the temperature equation part // int N2; // I = [0 1 0] fvScalarMatrix TEqn ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) // DT for thermal diffusivity + N2*(U&I)); // & operator is for dot product //); //TEqn.relax() TEqn.solve(); } runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } // ************************************************** *********************** // createfields.H Info<< "Reading transportProperties\n" << endl; IOdictionary transportProperties ( IOobject ( "transportProperties", runTime.constant(), mesh, IOobject::MUST_READ_IF_MODIFIED, IOobject::NO_WRITE ) ); dimensionedScalar nu ( "nu", dimViscosity, transportProperties.lookup("nu") ); // Adding Line dimensionedScalar DT ( "DT", // dimViscosity, transportProperties.lookup("DT") ); dimensionedScalar N2 ( "N2", transportProperties.lookup("N2") ); dimensionedScalar rho ( "rho", transportProperties.lookup("rho") ); dimensionedVector I ( "I", vector (0, 1, 0) ); // Done Info<< "Reading field p\n" << endl; volScalarField p ( IOobject ( "p", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field U\n" << endl; volVectorField U ( IOobject ( "U", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); // Adding lines for temperature field Info<< "Reading field T\n" << endl; volScalarField T // T is also volume property ( IOobject ( "T", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); // Done #include "createPhi.H" label pRefCell = 0; scalar pRefValue = 0.0; setRefCell(p, mesh.solutionDict().subDict("PISO"), pRefCell, pRefValue); mesh.setFluxRequired(p.name()); please help me with this thanks in advance |
make: Clock skew detected. build may be incomplete. while compiling new solver. | savee | OpenFOAM Programming & Development | 1 | May 27, 2017 06:23 |
Hybrid discretisation - blend factor | gcoopermax | CFX | 5 | September 23, 2016 08:05 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Compiling new Solver with wmake | lin123 | OpenFOAM | 3 | April 13, 2010 14:18 |
