temperature equation into interFOAM, undefined reference to ::typeName
Old   November 12, 2021, 05:21
Default temperature equation into interFOAM, undefined reference to ::typeName
Shibi is on a distinguished road
Hello to all,
I would like to implement the temperature equation into interFOAM on openFOAM 2106.
I found, what I consider to be, an elegant solution in Adding the Energy Equation to interFoam (OF 2.4.0) where a new myImmiscibleIncompressibleTwoPhaseMixture class is derived from immiscibleIncompressibleTwoPhaseMixture and the thermal part of the code gets implemented there.
I have followed the example, but upon compilation I get and error :
In function `Foam::incompressibleInterPhaseTransportModel<Foam::myImmiscibleIncompressibleTwoPhaseMixture>::type() const':
/home/of/OpenFOAM/OpenFOAM-v2106/src/phaseSystemModels/twoPhaseInter/incompressibleInterPhaseTransportModel/lnInclude/incompressibleInterPhaseTransportModel.H:106: undefined reference to `Foam::incompressibleInterPhaseTransportModel<Foam::myImmiscibleIncompressibleTwoPhaseMixture>::typeName'
collect2: error: ld returned 1 exit status
This happens when I change line 75 of createFields.H from:
typedef incompressibleInterPhaseTransportModel
    > transportModelType;
to:
    > transportModelType;
Can anyone help me fixing this?
Currently the class has:
.H
#ifndef myImmiscibleIncompressibleTwoPhaseMixture_H
#define myImmiscibleIncompressibleTwoPhaseMixture_H
#include "immiscibleIncompressibleTwoPhaseMixture.H"
namespace Foam
    class myImmiscibleIncompressibleTwoPhaseMixture
        public immiscibleIncompressibleTwoPhaseMixture
        protected:
        public:
            // Constructors
                //- Construct from components
                    const volVectorField& U,
                    const surfaceScalarField& phi
            //- Destructor
             virtual ~myImmiscibleIncompressibleTwoPhaseMixture(){}
           // No temperature related stuff are currently implemented
} // End namespace Foam
#endif
.C
#include "myImmiscibleIncompressibleTwoPhaseMixture.H"
namespace Foam
    defineTypeNameAndDebug(myImmiscibleIncompressibleTwoPhaseMixture, 0);
 Foam::myImmiscibleIncompressibleTwoPhaseMixture::myImmiscibleIncompressibleTwoPhaseMixture
    immiscibleIncompressibleTwoPhaseMixture (U,    phi)
The options file of the class:
EXE_INC = \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/OpenFOAM/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/transportModels/incompressible/incompressibleTwoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/transportModels/incompressible/lnInclude \
    -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
    -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \
LIB_LIBS = \
    -ltwoPhaseMixture \
    -lincompressibleTransportModels \
    -limmiscibleIncompressibleTwoPhaseMixture \
    -linterfaceProperties \
    -lfiniteVolume
The options file of the modified interFOAM
EXE_INC = \
    -I./myImmiscibleIncompressibleTwoPhaseMixture/myImmiscibleIncompressibleTwoPhaseMixture/ \
    -I$(FOAM_SOLVERS)/multiphase/VoF \
    -I$(LIB_SRC)/phaseSystemModels/twoPhaseInter/incompressibleInterPhaseTransportModel/lnInclude \
    -I$(LIB_SRC)/phaseSystemModels/twoPhaseInter/VoFphaseIncompressibleTurbulenceModels/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude \
    -I$(LIB_SRC)/dynamicFvMesh/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/phaseIncompressible/lnInclude \
EXE_LIBS = \
    -L$(FOAM_USER_LIBBIN) \
    -lmyImmiscibleIncompressibleTwoPhaseMixture \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools \
    -lsampling \
    -ldynamicFvMesh \
    -lturbulenceModels \
    -lincompressibleTurbulenceModels \
    -lwaveModels \
    -lVoFphaseTurbulentTransportModels
Thanks in advance!
Shibi is offline   Reply With Quote
Old   November 20, 2021, 06:29
Can anyone one give me hand with this?
Best Regards
Old   November 20, 2021, 06:48
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Best Regards
Interpreting the error message is not easy at first, but it states that typeName has not been defined. In OpenFOAM there are two frequently used macros "ClassName()" and "TypeName()". Both of these will add a declaration in your class for a typeName_() method and a typeName static const. You need a corresponding definition of the values in the C code, usually with the defineTypeNameAndDebug macro. Make certain that the c++ file is actually being compiled (and linked) and all should be fine.
olesen is offline   Reply With Quote
Old   October 6, 2025, 08:23
lixiaoyang
xyfoamer is on a distinguished road
I also face with this problem,if you solve it can you give me some suggestions?
xyfoamer is offline   Reply With Quote
can not complie fluentDataToFoam in OF2.1.1 hewei OpenFOAM Pre-Processing 20 September 8, 2018 10:19
wmake problems during custom utility compilation palazi88 OpenFOAM Programming & Development 11 August 13, 2018 21:52
OpenFoam 1.6-ext - RPM build errors preibie OpenFOAM 12 September 8, 2011 04:12
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
