January 20, 2023, 08:57 |
XiFoam dependance on initial conditions
Sarah
Rep Power: 3 |
Hi All!
I am using XiFoam solver to model flame propagation inside a rectangular cross-section, but I have observed that my solution depends a lot on the initial conditions of the case, like: mesh size, max Courant number, time step, initial values of k (turbulent kinetic energy). I am able to obtain good results for one set of conditions but as soon as I change the mesh (for grid independence study) my results change. Has anyone else faced any similar kind of problem with XiFoam or any other solver in OpenFOAM? If I can get any help regarding this situation, as how to proceed for grid independence study, I would be extremely grateful. By the way, I am using adaptive time step for the same. Thanks a lot in advance! |
February 1, 2023, 07:16 |
Tobias Holzmann
Rep Power: 51 |
Welcome to CFD. It all depends. If we change, e.g., the mesh or the numerical schemes, you will see the influence. Its normal but you should be aware which set-up you use, which parameter influences your stuff and so on.
Keep foaming, Tobias Holzmann |
Help sought on axial compressor simulation | jyotir | OpenFOAM Running, Solving & CFD | 0 | November 17, 2021 10:49 |
Compressible flows with larger Courant numbers | Tobi | OpenFOAM Running, Solving & CFD | 5 | February 26, 2021 15:20 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
