johanesp |
December 30, 2021 10:55 |
Cyclic conjugate heat transfer
I am investigating water flow through a heated internally rifled tube, using chtMultiRegionSimpleFoam (modelling heat transfer in both water and the tube). Until now I have been using a mesh with entrance region to ensure fully developed flow before the heating section, but I am interested in trying a cyclic approach. I have come across som examples for cyclic heat transfer of internal flows (as descirbed in Fully Developed Flow and Heat Transfer in Ducts Having Streamwise-Periodic Variations of Cross-Sectional Area by Patankar & Sparrow, 1977).
The basic idea is to define a modified pressure field,
where is the streamwise direction and is the pressure drop across the domain. The same can be done for temperature (assuming constant heat flux),
where is the temperature gradient, defined as
However, this is not shown for conjugate heat transfer, which I am interested in. I have not managed to find any examples of this yet, so I thought I should ask here if anyone has experience with this. If not, I think it should be possible to implement this in OpenFOAM without too much trouble. Any help is appreciated.
Best regards,
Johan
