InterFOAM+Temperature Equation + alpha update
Hi all, I am trying to implement my temperature equation to OpenFOAM.
I have an additional mass update that changes the cells at every timestep from gas to solid phase hence a change in density. After implementing what I think is correct, the temperature reading in the gas phase goes higher and higher until the simulation cannot solve anymore due to floating-point error, (is this what u call diverge?). Nevertheless, I would like to check with you guys if you happen to know what are things to look out for when implementing such a complex system? |
Help
Hi Anybody knows what are the issues?
For example, I am updating forAll(alpha1,celli) { if(some condition) { alpha1[celli] = 1.0; T[celli] = 1900; } } What are the things I need to lookout for when I update the Volume fraction alpha1? |
