Help with new volVectorField
I look in to steadyCompressibleFoam in foam-extend-4.1 and run the simple tutorial test like transonicbump.
The base code used U instead of field HbyA run well. When i create new volVectorField HbyA with same definition like below and replace U with HbyA, the code still run but divergence with wrong result. What is the trick here? Can anyone explain it? Code:
volVectorField HbyA = rUA*UEqn().H(); |
