Error using lookupObject()
Hi everyone,
I am working on a modified Version of the PaSR combustion model. In that I need to access a volScalarField which is being generated by my solver called "f". I am trying to do this using the code Code:
const volScalarField& F = this->mesh().lookupObject<volScalarField>("f"); Code:
Error: Expected primary-expression before ">" token Thank you very much! |
Check that you have "volFields.H" included somewhere, it could be that it simply does not know what volScalarField is in your chunk of code.
PaSR combustion model allready uses references to other volScalarFields, but those are stored in the turbulence model and can be accessed differently. |
Ok, I seemingly managed to solve the problem.
When I change the code to Code:
const volScalarField& F = this->mesh().objectRegistry::lookupObject<volScalarField>("f"); https://www.cfd-online.com/Forums/op...tionality.html I still don't understand the issue, as my C++ knowledge is very slim, but maybe this helps others who encounter this problem. |
