wind_ |
March 30, 2022 04:05 |
Error while compiling a solidParticle library based on interFoam in OF5x
In order to simulate the movement of bubbles in fluids, I am trying to couple the solidParticle library based on the interFoam. Follow the steps of this tutorial, http://www.tfd.chalmers.se/~hani/kur...Ghahramani.pdf and compile successfully in OF3.0.0.:)
But when I compile the same code in the new version OF5.x, I get the following compilation error,:mad:
solidParticleCloudI.H:77:79: error: no match for ‘operator=’ (operand types are ‘const Internal {aka const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>}’ and ‘Foam::tmp<Foam::Field<Foam::Vector<double> > >’)
tsource().internalField() = -smom_/(mesh_.time().deltaT().value()*mesh_.V());
In file included from /home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.H:366:0,
from /home/fxr/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvMesh.H:58,
from /home/fxr/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvCFD.H:7,
from interFoam.C:40:
/home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:424:6: note: candidate: void Foam::DimensionedField<Type, GeoMesh>::operator=(const Foam::DimensionedField<Type, GeoMesh>&) [with Type = Foam::Vector<double>; GeoMesh = Foam::volMesh]
void DimensionedField<Type, GeoMesh>::operator=
/home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:424:6: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::Field<Foam::Vector<double> > >’ to ‘const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>&’
/home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:445:6: note: candidate: void Foam::DimensionedField<Type, GeoMesh>::operator=(const Foam::tmp<Foam::DimensionedField<Type, GeoMesh> >&) [with Type = Foam::Vector<double>; GeoMesh = Foam::volMesh]
/home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:445:6: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::Field<Foam::Vector<double> > >’ to ‘const Foam::tmp<Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> >&’
/home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:469:6: note: candidate: void Foam::DimensionedField<Type, GeoMesh>::operator=(const Foam::dimensioned<Type>&) [with Type = Foam::Vector<double>; GeoMesh = Foam::volMesh]
/home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:469:6: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::Field<Foam::Vector<double> > >’ to ‘const Foam::dimensioned<Foam::Vector<double> >&’
In file included from solidParticleCloud.H:153:0,
from interFoam.C:47:
solidParticleCloudI.H: In member function ‘Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> > Foam::solidParticleCloud::AddToU() const’:
solidParticleCloudI.H:146:31: error: no match for ‘operator=’ (operand types are ‘const Internal {aka const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>}’ and ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’)
Usource().internalField() = correctU_;
/home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:424:6: note: no known conversion for argument 1 from ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’ to ‘const Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh>&’
/home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:445:6: note: no known conversion for argument 1 from ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’ to ‘const Foam::tmp<Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> >&’
/home/fxr/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/DimensionedField.C:469:6: note: no known conversion for argument 1 from ‘const vectorField {aka const Foam::Field<Foam::Vector<double> >}’ to ‘const Foam::dimensioned<Foam::Vector<double> >&’
/home/fxr/OpenFOAM/OpenFOAM-5.x/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt64Opt/interFoam.o' failed
make: *** [Make/linux64GccDPInt64Opt/interFoam.o] Error 1
And the part of source code solidParticleCloudI.H:
// 2Way Coupling- Momentum Source:
inline tmp<volVectorField> solidParticleCloud::momentumSource() const
tmp<volVectorField> tsource
new volVectorField
IOobject
"smom",
mesh_.time().timeName(),
mesh_,
IOobject::NO_READ,
IOobject::NO_WRITE
mesh_,
dimensionedVector
"zero",
dimensionSet(1, -2, -2, 0, 0),
vector::zero
//tsource().primitiveFieldRef() = -smom_/(mesh_.time().deltaT().value()*mesh_.V());
return tsource;
Anyone can help me?:confused:
Thanks in advance
