Calling MPI routines in OpenFOAM
Old   July 19, 2022, 06:15
Default Calling MPI routines in OpenFOAM
Doğukan Teber
dogukanteber is on a distinguished road
I have been trying to parallelize the decomposePar utility in OpenFOAM, for more information https://www.cfd-online.com/Forums/openfoam-programming-development/243964-parallelizing-decomposepar-utility.html) Therefore, I need to call MPI routines in my new utility. I learned that OpenFOAM has Pstream wrapper for MPI routines. However, my program throws an error when I do not call decomposePar before I run the program. For instance, below is a basic hello world program:
 #include "fvCFD.H"
 int main(int argc, char* argv[]) {
   #include "setRootCase.H"
   #include "createTime.H"
   // cannot run in parallel without creating processor0 directory
   Pout << "Hello from process " << Pstream::myProcNo() << endl;
   return 0;
Here are the commands that I execute in order (assume I have compiled my source file):
blockMesh
mpirun -np 4 <program-name> -parallel
And, here is the error message:
Pstream initialized with:
   floatTransfer   : 0
   nProcsSimpleSum  : 0
   commsType     : nonBlocking
   polling iterations : 0
 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
 fileModificationChecking :  Monitoring run-time modified files using timeStampMaster  (fileModificationSkew 5, maxFileModificationPolls 20)
 allowSystemOperations : Allowing user-supplied system call operations
 [0]
 [0]
 [0] --> FOAM FATAL ERROR: (openfoam-2106)
 [0] parallelDecompose: cannot open case directory "/home/dogukan/Documents/hydrology/tutorials/permaFoam/demoCase/processor0"
 [0]
 [0]
 FOAM parallel run exiting
 [0]
 MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
 with errorcode 1.
 NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
 You may or may not see output from other processes, depending on exactly when Open MPI kills them.
When I call below functions, everything works as expected:
blockMesh
decomposePar
I want to run my program after I call blockMesh so that I can parallelize the decomposePar utility. Is it possible to use Pstream methods without calling the decomposePar utility?
OpenFOAM version: v2106
Thanks in advance
dogukanteber is offline   Reply With Quote
decomposepar, mpi, openfoam
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[OpenFOAM.com] Install OpenFOAM 3.0.1 on cluster without root access; mpi error Madeinspace OpenFOAM Installation 1 July 4, 2020 14:16
MPI profiling OpenFOAM damBreak3D application mellanoxuser OpenFOAM Pre-Processing 0 April 13, 2008 23:15
MPI profiling OpenFOAM damBreak3D application mellanoxuser OpenFOAM Running, Solving & CFD 0 April 13, 2008 23:04
