Add source term in icoReactingMultiphaseInterFoam VOF equation
Dear Foamers
I'm looking into icoReactingMultiphaseInterFoam for a laser melting case with added mass (blown powder or wire). I had a look at the solver structure but cant find the alphaEqn.H file. I would like add a source term for the liquid phase in the corresponding VOF equation. Any idea how to proceed? many thanks in advance, Chuikov |
Peace,
the alpha equation is integrated inside of the >>fluid.solve()<< routine of the multiphaseSystem class. The solve() function then calls the function >>solveAlphas()<< function. My ideas would be: 1.) calculate your source term and add it to the equation. Ensure that this term is zero for the other phases 2.) Conditional statement and just add your source term if the condition is met Copy that library in you rown library folder recompile that library into FOAM_USER_LIBBIN (best under a different name) change inside the Make/options file inside the icoReactingMultiphaseInterFoam directory the source directory of your library and the library name |
many thanks for your kind assistance!
looks like quite a complex function, I will try my luck with a coded source via fvOptions cheers! |
