September 8, 2022, 04:58 |
post-processing solver
krishna kant
Rep Power: 10 |
Hello Foamers
I am trying to make my own customize post-processing solver. I guess it is not so difficult thing. However I am unable to find any right source or link for my guidance. If anyone knows then please tell. My actual problem is let say I have run a rising bubble problem. I have saved my time step data for N number of steps (0, 0.1, 0.2, ...). I want to make a solver which loop over to read the data for each N step case and do my calculation with those data (lets say calculate bubble centroid) and I create an output data file for each N step like Xc(0, 0.1, 0.2 ...). I am having trouble in writing the loop. What should be the syntax to read over each time step file. Thanks |
September 8, 2022, 06:07 |
krishna kant
Rep Power: 10 |
Hello All,
I am able to write the solver. It is a derivative of postProcess.c. It is giving results. However, I am getting a warning like this --> FOAM Warning : From function bool Foam::dictionary::add(Foam::entry*, bool) in file db/dictionary/dictionary.C at line 807 Reading "" attempt to add entry functions which already exists in dictionary "" It is because I am using the same create fields as in my simulation solver. How can I suppress this warning? Coz in a long run it can be time consuming as well. Thanks |
Post Processing Results: Ansys Workbench 18.2 - Fluent - CFD Post - Porous Body | onlycfd | CFX | 4 | April 29, 2021 03:02 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Solver Monitor Plot value is different than Post function calculator value | GT_turbo | CFX | 0 | February 15, 2016 11:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 06:21 |
