Unable to abort OF when file not found in subroutine
Old   September 8, 2022, 03:43
Default Unable to abort OF when file not found in subroutine
TWB
quarkz is on a distinguished road
I have written a code to deform/rotate my mesh.
I need it to read in the rotation rate from a text file, and abort OF if the file is not found.
I googled and also search the forums. I tried:
1. exit(1);
2 .exit();
elevatorRotation_simpleFB.C:133:9: error: no matching function for call to ‘exit()’
133 | exit();
3. stopAt(Time::saNoWriteNow);
elevatorRotation_simpleFB.C: In member function ‘virtual Foam::septernion Foam::solidBodyMotionFunctions::elevatorRotation_s impleFB::transformation() const’:
elevatorRotation_simpleFB.C:135:4: error: ‘stopAt’ was not declared in this scope
135 | stopAt(Time::saNoWriteNow);
4. abort();
elevatorRotation_simpleFB.C:137:10: error: no matching function for call to ‘abort()’
137 | abort();
but all can't work, giving error msgs as shown above during compilation.
Can someone help? Did I miss out some include files?
Thanks
quarkz is offline   Reply With Quote
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 16:05
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
