Add scalar "shift" to an already computed simulation
Like Tree1Likes
  • 1 Post By jcoelho5
Old   September 12, 2022, 09:39
Default Add scalar "shift" to an already computed simulation
Joao Coelho
jcoelho5 is on a distinguished road
Hi all,
does anyone know if it is possible to modify a field by adding/subtracting a scalar shift to an already computed simulation?
Example: I computed a simulation with one BC of pressureOutlet of 5 bar. If I want to repeat the simulation with a new BC of 15 bar instead, if I continue the simulation from the previous (with a 5 bar BC), the transient would take too much time, and (when possible to use) the steady state simulation also tend to fail. My idea was to add 10 bar to all the scalar pressure field, and proceed to simulate from that state.
Thanks in advance for any suggestions.
Best regards to the forum!
jherb likes this.
jcoelho5 is offline   Reply With Quote
Old   September 13, 2022, 19:00
Joachim Herb
jherb is on a distinguished road
With funkySetFields you could change the internal field, but I have not found a method to do this also for the boundary files (funkySetFields will overwrite them with zeroGradient boundaries if you do not turn off modifying boundaries alltogether)
jherb is offline   Reply With Quote
Error in New Surface reaction model (Having multiple reactions) surajkvs OpenFOAM Programming & Development 2 May 23, 2023 21:21
Temperature calculation from total enthalpy in OpenFOAM (XiFOAM) sharifi OpenFOAM Running, Solving & CFD 1 October 8, 2020 09:16
ERROR: request for volScalarField thermo:psi from objectRegistry region0 AAbouali OpenFOAM Running, Solving & CFD 1 September 19, 2020 04:53
Non uniform temperature gradient Nabeel Abed OpenFOAM Programming & Development 2 August 20, 2019 08:10
add user scalar in one phase zhu CFX 0 April 27, 2002 03:45
