modified stochasticDispersionRAS
Like Tree1Likes
  • 1 Post By CGuaq
Old   September 15, 2022, 11:22
Default modified stochasticDispersionRAS
Charles Guaquiere
CGuaq is on a distinguished road
I try to modify stochastic dispersion model on Open FOAM to improved my results concerning particles deposition. I found a tutorial from Chalmers University:
http://www.tfd.chalmers.se/~hani/kur..._Xu_Report.pdf
I changed the stochasticDispersionRAS.C and the stochasticDispersionRAS.H like in the tutorial but it used Open FOAM 4 and I use Open FOAM 9. My problem is on the following part of the code (from line 96 to 103):
const word turbName= IOobject::groupName
turbulenceModel:: propertiesName,
this->owner().U().group()
const turbulenceModel& turbModel = obr.lookupObject<turbulenceModel>(turbName);
I changed all "turbulenceModel" by "momentumTransportModel" concidering the modifications between Open FOAM 4 et 9 but "propertiesName" is no longer defined in momentumTransportModel.C and momentumTransportModel.H like it was on Open FOAM 4. I don't know how to modify this part of the code to make it works on Open FOAM 9.
I don't have enough experience developing code on OpenFoam yet, so please can someone help me ?
Kind regards,
francois likes this.
CGuaq is offline   Reply With Quote
Old   September 23, 2022, 12:20
Francois Beaubert
francois is on a distinguished road
Any idea where to find some helpful pointers on this particular point ?
francois is offline   Reply With Quote
Old   September 23, 2022, 23:05
Chen Xiaoxiao
SmileMax is on a distinguished road
In fact, turbulenceModel:: propertiesName corresponds to the generic turbulence dictionary name, such as turbulenceProperties in OpenFOAM(.com) or momentumTransport in OpenFOAM(version 8+, .org) , and this->owner().U().group() corresponds to your phase name.
so you can use the following simplified form:
    "momentumTransport.<phase name>"
SmileMax is offline   Reply With Quote
Old   September 26, 2022, 06:32
Charles Guaquiere
Thanks for your reply,
Unfortunatly it does not work, are you sure it is momentumTransport.<phase name> and not momentumTransportModel.<phase name> ? Because OpenFOAM suggested me to use "momentumTransportModel_H" instead of "momentumTransport" when I compile the code.
Also, how can I find my phase name to replace in your simplified form because "phase name" is not declared.
Thank you in advance for your answer
Old   September 26, 2022, 07:56
Chen Xiaoxiao
You'd better be able to provide the error message output by the compiler.
Old   September 26, 2022, 09:26
Charles Guaquiere
Sorry it is my first time on CFD Online.
I think I found the solution by compararing files like shearStress.C or yPlus.C, so I changed my previous code into:
                    momentumTransportModel::typeName,
                    phaseName_
The error message has disappeared since this modification. But now I have a new error message concerning the following part of the code (line 43 to 55):
yP_
    	IOobject
    	"yP",
    	this->owner_.mesh().time().typeName(),
    	this->owner_.mesh(),
    	IOobject::NO_READ,
    	IOobject::AUTO_WRITE
    	dimensionedScalar("yP", dimless, 0.0)
This is the error message:
i'm not sure what that means.
Old   September 26, 2022, 09:33
Chen Xiaoxiao
                    phaseName_
yP_
        IOobject
        "yP",
        IOobject::NO_READ,
Attachment 91684
This seems to be a basic syntax error in the C++ language.
Old   September 26, 2022, 10:45
Charles Guaquiere
Do you have any idea what i can modify to make it works on OpenFOAM 9 ? I tried modifications but nothing works.
thank you in advance
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 19 June 11, 2020 16:54
Problem while compiling modified simpleFoam solver mattiafc OpenFOAM Programming & Development 0 May 26, 2020 21:01
why in solve(UEqn == -fvc::grad(p)) UEqn.source() is not modified and UEqn.H() chang mAlletto OpenFOAM 1 January 1, 2019 12:59
Modified rhoCentralFoam slip boundary fails in parallel ChrisA OpenFOAM Programming & Development 0 June 25, 2014 21:28
Modified Equation for CFX algorithm Craig Johansen CFX 0 August 28, 2004 00:02
