How to add turbulence model and VOF to a new two-step projection OpenFOAM solver
Old   October 30, 2022, 08:36
Default How to add turbulence model and VOF to a new two-step projection OpenFOAM solver
Shuo Mi
Msure is on a distinguished road
Hello everyone,
I wrote an OpenFOAM solver using two steps projection method, not using original PISO or PIMPLE in OpenFOAM. The second-order Adams-bashforth for time scheme is used.
        fvVectorMatrix UEqn
          fvm::ddt(U)
          + 1.5*fvc::div(phi, U) - 0.5*fvc::div(phi.oldTime(), U.oldTime())
          == 1.5*fvm::laplacian(nu, U) - 0.5*fvc::laplacian(nu, U)
          + 0.5*fvc::grad(p)
        fvScalarMatrix pEqn
            fvm::laplacian(p) == 2.0/3.0*fvc::div(phi)/dt
I got two questions, thanks for everyone who has some ideas about this:
1. How to add turbulence model?
Is it right that using nuEff() to replace the nu directly?
2. How to add VOF model?
I have no idea about this.
Thanks a lot!
Regards,
Shuo
Msure is offline   Reply With Quote
Old   November 3, 2022, 15:08
Federico Zabaleta
fedez91 is on a distinguished road
Hello Msure
1- You should check out the implementation of turbulence in other models, such as pisoFoam. It is done by creating a pointer in createFields.H that points to the selected turbulent closure. Then the function turbulence->divDevReff(U) is used to obtain the viscous and turbulent stresses. You can replicate this procedure in your solver. Check that other functions are used throughout the solver to, for example, solve the turbulent closure equations. You can take a look a this presentation for more information.
2- To add VOF take a look at the implementation of interFoam. You can check this thesis to see details of the implementation.
I hope this helps,
Federico
fedez91 is offline   Reply With Quote
Old   November 3, 2022, 15:24
Shuo Mi
thanks Federico, these documents are useful.
openfoam, turbulence models, vof
Divergence detected in AMG solver. VOF. Mr.Mister Fluent Multiphase 4 September 25, 2023 07:10
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 5, 2018 23:48
Which solver in OpenFOAM corresponds to the Eulerian Model in FLUENT? paradism OpenFOAM 1 March 20, 2017 09:35
Help Selecting Turbulence Model for VOF Problem NavierIsStoked FLUENT 0 November 1, 2013 11:27
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 22:00
