January 11, 2023, 03:47 |
Set dimensionless in foam-extend-5.0
Nguyen Trong Hiep
Rep Power: 7 |
Hi all,
i want to create a volScalarField have dimensionless with zero initialization. Code:
volScalarField field ( IOobject ( "field", mesh.time().timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE, false ), dimensionedScalar(dimless, Zero) ); Code:
error: no matching function for call to ‘Foam::dimensioned<double>::dimensioned(const Foam::dimensionSet&, const Foam::zero&)’ dimensionedScalar(dimless, Zero) |
January 11, 2023, 04:22 |
Rep Power: 3 |
give it a name: dimensionedScalar("someName", dimless, Zero)
and the mesh also: volScalarField field ( IOobject ( "field", mesh.time().timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE, false ), mesh dimensionedScalar("someName",dimless, Zero) ); |
January 11, 2023, 04:30 |
Nguyen Trong Hiep
Rep Power: 7 |
Thank you very much
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] mergePatchPairs problem when using two master and slave combination | Ali_Sh | OpenFOAM Meshing & Mesh Conversion | 0 | September 22, 2021 09:35 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
