schradc |
February 4, 2023 21:15 |
Adding a Constructor to ThermoCloud
I have a novice question, I'm not quite sure how to articulate it.
I need to modify the ThermoCloud class to add a constructor with a modified list of arguments. Presently the constructor takes these arguments
ThermoCloud
const word& cloudName,
const volScalarField& rho,
const volVectorField& U,
const dimensionedVector& g,
const SLGThermo& thermo,
bool readFields = true
I need to avoid passing an instance of SLGThermo and instead pass select data it contained individually.
Initially, I wanted to create a copy of ThermoCloud with the same inheritance and add the custom constructor, but there is a hitch.
src/lagrangian/intermediate/submodels/Thermodynamic/HeatTransferModel/HeatTransferModel/HeatTransferModel.H
#define makeHeatTransferModel(CloudType) \
typedef Foam::CloudType::thermoCloudType thermoCloudType; \
defineNamedTemplateTypeNameAndDebug \
Foam::HeatTransferModel<thermoCloudType>, \
0 \
namespace Foam \
defineTemplateRunTimeSelectionTable \
dictionary \
If I am understanding this correctly, the runTimeSelction stuff for the HeatTransferModel (and derived) can only be done for cloud classes which are templated based on and are derived from a ThermoCloud. Which means that no matter what I do, I will have to at some point construct a ThermoCloud using the SLGThermo constructor.
I could use some advice on how to proceed.
- Do I need to modify the heat transfer runTimeSelection macros to work with a custom "ThermoCloud adjacent" class?
- Can/should I add a constructor to the actual ThermoCloud class instead of deriving from it?
- Can I set the data inherited from ThermoCloud without using the ThermoCloud SLGThermo constructor? Perhaps using the default constructor? If I do, how do I construct the KinematicCloud on which ThermoCloud is based?
Thanks for taking a look.
